3D Invig transfer?
COW Forums : Zaxwerks
eric sampson
3D Invig transfer?
on May 15, 2006 at 9:55:27 pm
When we bought After Effects 6 we got a free plug-in for 3D Invig. I think it was just the classic version. Im wondering if I upgrade to After Effects 7 will that free plug-in still work?
Jon Okerstrom
Re: 3D Invig transfer?
on May 16, 2006 at 12:48:56 am
Hi Eric,
From the FAQ: "If you are running After Effects 6.5 you must use Classic 3.0.9 or PRO 4.0 or higher. The 3.0.8 and lower versions are not compatible with AE 6.5."
Also, Zaxwerks.com lists Classic 4.06 as current and compatible with AE7. The best advice would be to use the most current version. Check the downloads section of Zaxwerks.com for updates or upgrades.
Jon
