transparency and ProAnimator on OSX
COW Forums : Zaxwerks
Mathieu
on May 15, 2006 at 9:38:31 pm
Hi guys,
I'm working in a scene with 4 cubes from illustrator files. I'm trying to make them transparent with the TRANSPARENCY parameter un the object property so tha I can see one cube passing behind the others. The thing is bringing the transparency to 0 or to 100 doesn't seems to make much difference. Is that how I'm supposed to do it?
Thanks a lot
Mat
Jon Okerstrom
Re: transparency and ProAnimator on OSX
on May 16, 2006 at 12:37:51 am
Hi Mat,
The transparency slider affects the transparency of the material you're editing. If that material is the one applied to all six sides of the cube, moving the slider will affect the transparency of all six sides of that object.
If that material is applied to only some of the sides, the slider will affect the transparency of only those sides.
Also, any reflection map and setting you're using on the object will make a difference when it comes to transparency.
Does this help?
Jon
