jaggies
COW Forums : Zaxwerks
mark wilkinson
jaggies
on May 14, 2006 at 6:41:19 am
ive got some text that came from an illustrator file. the faceting is set at its lowest and im
getting a bit of a jaggy effect down a diagonal edge of the letters. what might be the cause ?
cowcowcow
Jon Okerstrom
Re: jaggies
on May 15, 2006 at 1:10:38 am
Hi Mark,
Are you looking at draft or best quality rendering when you're seeing the jaggies? The faceting setting normally has the most impact on rounded edges, rather than straight lines.
If you're looking at it very, very closely, it may be your antialiasing setting.
It would be most helpful if you could post an image demonstrating the issue you're having.
Jon
mark wilkinson
Re: jaggies
on May 15, 2006 at 7:44:31 am
thanks for your response jon, i have the layer set to "best" and the faceting on "best" set to .1
you can see the effect on the diagonal of the letter A here.
http://www.headwatersdesign.com/image.png
Jon Okerstrom
Re: jaggies
on May 15, 2006 at 1:22:19 pm
Hi Mark,
The image file you uploaded is very, very small. The resolution is so low you're bound to get stair stepping when you zoom in. s that the size of your final render?
Jon
cowcow
mark wilkinson
Re: jaggies
on May 15, 2006 at 9:03:02 pm
no i just clipped that bit to show you how it looks.
try the same link again for another look. its just on the W and the As it looks
less than crisp.
Jon Okerstrom
Re: jaggies
on May 16, 2006 at 12:33:41 am
Hi Mark,
It looks like the wrong image is linked now.... a title page.
Jon
