What have i done that is not correct?
COW Forums : Zaxwerks
evrard
on May 14, 2006 at 3:07:30 am
I was trying to create a 3D object in proAnimator (and in invigorator) from an AI file.
ProAnimator says "there is no usable vector path in your file" and closes.
How did i create the AI file? I simply opened Illustrator CS2, grabbed the pencil tool and drawn. I then saved as AI. And i clearly see the drawn object within Illustrator.
Was there something alse i should do in AI? what does this error message mean? What is a "usable vector path" and how is it different from what iam seeing in Illustrtor right now?
Thank you
PS: I am totally new to illustrator.
Serge
Re: What have i done that is not correct?
on May 14, 2006 at 5:24:23 am
When saving your file, disable the "Use compression" check box.
Salut.
Serge
"InvigoMany" now available here:
http://www.nyc-visual.com
