texture for sphere
COW Forums : Zaxwerks
Damon Surzyshyn
texture for sphere
on May 11, 2006 at 10:15:13 pm
I'm having trouble mapping a texture to a sphere primitive...it keeps pinching the texture map in the centre. I am using a 1440x486 PSD as the texture for a 720x486 comp. Any ideas?
Damon Surzyshyn
Serge
Re: texture for sphere
on May 11, 2006 at 11:39:09 pm
Your texture map should have an aspect ratio of 1:2 (1440 X 720 or 972 X 486 for instance)
What are you trying to create?
Salut.
Serge
Damon Surzyshyn
on May 11, 2006 at 11:59:10 pm
OK...I'll try it at the 1440 x 720...I was using the dimensions that usually work for me with CC sphere.
I am trying t make a baseball with a logo on it...I made a PSD with a peanut shaped path that i stroked with a red pound symbol looking brush that makes half assed looking stitches...I also made another version that was 50% gray with a white stroke that i use as a bump map.
Any other suggestions on how i can get it looking a little better are apreciated.
Damon
Serge
on May 12, 2006 at 12:18:12 am
Hi Damon,
You should also consider painting the holes for the stitches and use this map as a transparency map.
You would then need to place a second black sphere inside of your baseball to get dark holes.
Your bump map should also have a kind of leather texture.
I have a Baseball on my site http://www.nyc-visual.com if you want to have a look at it.
Salut.
Serge
"InvigoMany" now available here:
