 | Which 3D Applications' Models Does Invig Pro Support?
on May 11, 2006 at 3:18:57 pm |
Can Invigorator Pro support 3D models in either .max or .3Ds format?
May I suggest that you revise your website to list which 3D application's models can be imported. At the moment, you only show some outdated icons, and being a 3D rookie, I don't recognize them! I also suspect that many of them are outdated, or from Mac OS 9 days.
Thanks for the help,
Dave
 | Re: Which 3D Applications' Models Does Invig Pro Support? on May 11, 2006 at 4:55:38 pm |
[David Shough] "Can Invigorator Pro support 3D models in either .max or .3Ds format?"
Yes you can import .3ds models but not .max models.you can also import Maya,Lightwave and Cinema4d models
 | Re: Which 3D Applications' Models Does Invig Pro Support? on May 11, 2006 at 5:16:36 pm |
Thanks very much for the help.
Dave
