Pro animator 3 help
COW Forums : Zaxwerks
David
Pro animator 3 help
on May 9, 2006 at 2:53:15 pm
Hi guys
I am using Adobe Illustrator CS2 and want to insert files i have made in CS2 to Pro animator 3. I am having a bit of trouble with this process. I have used the pen tool in AI CS2 to draw a shape closed the paths and saved it as an AI file. when i attempt to insert the file in to pro animator i get the message "not enough memory" could someone help me please.
Serge
Re: Pro animator 3 help
on May 9, 2006 at 8:56:51 pm
Hi David,
Are you using the latest version of ProAnimator 3?
Does this happen with other ai files?
Did you uncheck "Use Compression when saving your ai file using CS2?
Let us know.
Salut.
Serge
"InvigoMany" available here:
http://www.nyc-visual.com
