Help Resetting Default Materials and Swatches in Animator 3.02
COW Forums : Zaxwerks
susan22
on May 9, 2006 at 2:42:42 am
Somehow I killed all my swatches and materials so that they are now gray boxes. Animator is not very intuitive to me yet and I see no reset boxes.
Is there some way I can easily reset all the materials and swatches to factory default. Do I need to be a folder geek and drag things around?
Thanks for your help.
sussan22
Jon Okerstrom
Re: Help Resetting Default Materials and Swatches in Animator 3.02
on May 9, 2006 at 3:44:45 am
Hi Susan,
The answer depends on what you did to the swatch library. If you changed the hierarchy of the folders or moved the application, that could cause problems. Restoring the correct hierarchy could restore the library.
Also, if you deleted the swatches from the bins, that will remove them from the disk. (You'll get a warning before you do this.)
In either case, the simplest idea would probably be a clean install.
Jon
