How to create a ring, that is cylinderical all the way around?
COW Forums : Zaxwerks
Chrisco
on May 6, 2006 at 4:06:06 am
Hey guys
I need to make a ring shaped object, that is like a a circluar pipe, rather than some of the half pipe options.
Everything i have come accross makes it curved onthe outside of the ring and the inside is iether hollow (not the Front and Back Faces) or soemthign different.
I have Invig 4pro.
Chrisco
Serge
Re: How to create a ring, that is cylinderical all the way around?
on May 6, 2006 at 4:43:23 am
If I got you right, you are looking for a "Torus". As you have Invigorator 4.0 (Make sure you upgrad for free to 4.0.7) You could create one right away by selecting: Object>Create 3D Primitive. Invigorator will first create a sphere but you could then once you select the sphere turn it to a torus in the Object menu.
Does this help?
Salut.
Serge
"InvigoMany" is available here:
http://www.nyc-visual.com
