.JPEG to Illustrator?
COW Forums : Zaxwerks
ZackMI
on Apr 11, 2006 at 3:41:19 pm
HI All,
I am working on a project for the United Way and I have their logo in .jpeg and .tif and I want to convert it to an illustrator file and then bring it in to Invigorator to make 3d. Is this possible becuase I'm having no luck! Thanks ahead!
John Dickinson
Re: .JPEG to Illustrator?
on Apr 12, 2006 at 3:05:16 am
There is no quick solution to making the paths Invigorator requires. You could try the tracing feature in Illustrator (Live Trace in CS2) but I find I usually have to go in and adjust the paths manually to get them right. Best case is to get an AI or EPS file from the client if at all possible.
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
_Perch
on Apr 13, 2006 at 1:55:58 pm
You may check brandsoftheworld.com, they should have a national UW logo that will work, unless you're looking for local/regional UW logo.
TC
