dashed circle
COW Forums : Zaxwerks
doug
dashed circle
by
on Mar 30, 2006 at 7:44:58 pm
Hello,
I have a quick question. I have a Dashed Circle from illustrator that I want to use in Zaxwerks. The problem is when i open it in Zaxwerks it comes out as a solid circle with out the dashes. Any Help would be appreciated.
Hail the Cow!
Doug
John Dickinson
Re: dashed circle
on Mar 30, 2006 at 10:56:06 pm
Each circle needs to be an individual path. Expanding the stroke won't work so you need to create this manually. Just make one small circular path, set your centre point (by selecting the Rotation tool and Option/Alt clicking where you want the centre of the circle to be). In the resulting dialog box set a degree amount, then click Copy. Then just click Command/Control D to duplicate the path until you've formed a circle. Now you have a circle of circular paths which you can save and import into 3D Invigorator.
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
doug
Re: dashed circle
by
on Mar 30, 2006 at 11:44:26 pm
thank you sir
