Bounding Box Question revisited...
COW Forums : Zaxwerks
cowcowcowcowcow
Betty Boop2
on Mar 29, 2006 at 10:58:25 pm
Here's what I'm doing...
http://www.jtdesign.org/AmericasBest/Downloads/DaVinci.zip
As you can see the logo was cereated within ProAnimator but when I bring it back into AE 7.0 the bounding box is too tight. I really would like to have the bounding box the size of the comp.
Any ideas???
Jay Thompson
Thompson Visual Design & Storytelling
7 Marjean Ct.
Kirkwood, MO 63122
cowcowcowcowcow
John Dickinson
Re: Bounding Box Question revisited...
on Mar 30, 2006 at 1:49:31 am
This zip won't open on my system. Are you applying ProAnimator to a comp-sized solid?
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
Betty Boop2
on Mar 30, 2006 at 2:05:24 am
Hi John,
I was hoping that you might answer. Here is a link that should work...
http://www.jtdesign.org/AmericasBest/Downloads/DaVinci-2.zip
Ys, I was applying Pro animator to a comp-sized solid.
Jay Thompson
7 Marjean Ct.
Kirkwood, MO 63122
John Dickinson
on Mar 30, 2006 at 2:13:59 am
Well it looks okay to me, nothing looks cropped off... Why did you precompose the solid before applying ProAnimator?
JD
John Dickinson
Motionworks
John Dickinson
on Mar 30, 2006 at 2:21:17 am
Okay, I notice that you've applied to ProAnimator to a precomposed solid inside DaVince-type. The precomposed solid is 720 x 486 but DaVince-type comp is 1620 x 824. So that means you AREN'T applying ProAnimator to a comp sized solid, if you were the solid would need to be 1620 x 824. One way around this is to activate the Collapse Transformations button for the ProAnimator layer inside the DaVince-type comp, this will extend the boundaries of the layer.
John Dickinson
Motionworks
Betty Boop2
on Mar 30, 2006 at 3:18:35 pm
Thanks John. I'll try that.
Jay Thompson
7 Marjean Ct.
Kirkwood, MO 63122
