• | Tubular Text?
on Feb 9, 2006 at 2:07:57 pm |
Is it possible to create tubular text? If so, any tips?
• | Re: Tubular Text? on Feb 10, 2006 at 1:24:06 am |
Hi Scenecutter,
The half pipe bevel will give you rounded edges. Combining that with very thin, stick-like text should work for you. You can easily create tubular neon lights by using the pen tool to do a continuous line word... try a stroke weight of 1 point. Then select the object, and use path>outline, to create a solid filled object. Apply the half-pipe bevel and adjust to taste.
Does this help?
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 1:24:42 am |
Hi Scenecutter,
Does this help?
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 1:25:05 am |
Hi Scenecutter,
Does this help?
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 1:25:06 am |
Hi Scenecutter,
Does this help?
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 1:25:29 am |
Hi Scenecutter,
Does this help?
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 1:25:40 am |
Hi Scenecutter,
Does this help?
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 1:25:41 am |
Hi Scenecutter,
Does this help?
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 1:25:47 am |
Hi Scenecutter,
Does this help?
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 1:27:07 am |
Okay, the multiple post thing is really weird.
Sorry about that.
Jon
• | Re: Tubular Text? on Feb 10, 2006 at 2:08:33 am |
Yes Jon, we got it the first time ;0)
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
