zaxwerks 3d flag works ok but crashes when project is resaved
COW Forums : Zaxwerks
Paul Hanson
on Feb 9, 2006 at 1:01:52 pm
Can anybody shed some light on this problem,
I'm using zaxwerks 3d flag which works fine and saves fine, but when the project is called up and adjustments made and you try to resave after effects crashes, and you do not want to emergency save as this just crashes every time you try to open it. The error message reads thus "After effects error: crash occurred while invoking effect plug-in "3D Flag"".
This happens on both of my macs - g5 dual 2g and g5 dualcore 2.7g, both machines also have 3d invigorator on them and are running ae 6.5 with pal comps.
I've checked the archive and can't find anything relating to this.
ta v much
Paul
John Dickinson
Re: zaxwerks 3d flag works ok but crashes when project is resaved
on Feb 9, 2006 at 10:40:23 pm
First question: are you using the latest version of Flag? You can check on the Zaxwerks site.
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
Paul Hanson
on Feb 13, 2006 at 10:27:50 am
I'm using version 1.0.1, which we purchased from zaxwerks about 4 weeks ago.
Kind regards
Paul Hanson
Asaf Billet
on Feb 22, 2006 at 6:13:34 pm
Im getting this too.
VERY annoying.
I had to remove the plugin from the Plugins folder just so I could open my project and
clear the effect. Any news on that ?
cheers
ace
Intel Inside, the world's most popular warning label.
Brad Chmielewski
on Mar 14, 2006 at 3:04:41 am
Any news have the same problem on my G5 2 ghz iMac.
