Finding Invigorator Layer in 3D Space
COW Forums : Zaxwerks
Tigwell
on Jan 30, 2006 at 4:38:45 pm
Hi there,
I'm using invigorator layers in a 3d comp with the invigorator layers being seen by the comp camera.
I want my camera to fly off and spin away in quite a large space.
my problem is that i can't 'find' my invigorator text layers once i have 'spun' away. i'm changing the parameters of the Sets of the effect but its really hard to control where the type goes...
is it possible to parent my invigorator type to the camera or a 3d null?
Any other way to make working with this easier?
thanks,
Neil
John Dickinson
Re: Finding Invigorator Layer in 3D Space
on Jan 31, 2006 at 1:59:25 am
If you are using the Pro version 4 you can link your invigorator to an AE 3D layer using 3D object tracking:
http://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=41&page=...
This make it very easy to see where your invigorator object is in AE's 3D space.
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
Markus
on Feb 4, 2006 at 12:35:52 am
Maybe you can take a solid layer as a 3D dummy. Take the position parameter from the invigorator and put it to the dummy layer.hope this helps.
markus
