Lighting question...
COW Forums : Zaxwerks
Betty Boop2
on Jan 28, 2006 at 3:43:51 pm
So...I have this logo created in Pro Animator (the new plug-in version to After Effects), and I want to animate lights around it in AE. Can some one explain the procedure I should follow.
Thanks in advance.
Jay Thompson
Thompson Visual Design & Storytelling
7 Marjean Ct.
Kirkwood, MO 63122
Jon Okerstrom
Re: Lighting question...
on Jan 28, 2006 at 6:27:49 pm
Hi Jay,
How about some clarification to your question...
If you mean you want to use comp lights and animate their position, that's no problem. Just check the "use comp lights" feature, in the effects panel. Add one or more comp lights to your scene then animate the position, point of interest and other attributes for your lights. The changes you make will be seen on the Invigorator objects.
If you mean you want to animate visible light sources, that's another matter. Tell us more about the look you're going after and we may be able to help.
Jon
Betty Boop2
on Jan 28, 2006 at 8:28:17 pm
Thanks Jon! That was exactally what I needed to know.
Jay Thompson
7 Marjean Ct.
Kirkwood, MO 63122
