file saving issue...
COW Forums : Zaxwerks
Betty Boop2
on Jan 11, 2006 at 5:26:46 pm
I know that in Pro Animator can save a scene (a finished model and animation) also called a .zxa file, however I have a lot Invigorator Pro logos I've done within AE.
What I like to know is there anyway to save them as .zxa files??? Or scenes? Or is there anyway to import IP stuff into Pro Animator? Any options here?
Jay
John Dickinson
Re: file saving issue...
on Jan 11, 2006 at 8:03:25 pm
Whilst inside 3D Invigorator Pro just hit Command (mac) Control (windows) S to save the scene, then you can open that scene up in Pronimator using the OPEN SCENE command. It doesn't bring in any animation however. You can also choose to export the selected 3D object as a .ZXO file. To do this, select the object, click on the Object Popup menu and choose Export 3D model. Hope that helps :)
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
Betty Boop2
on Jan 12, 2006 at 3:37:04 am
Great! Thanks John.
Oh...what if you are using Invigorator Pro within AE (as a plug-in), not the stand alone. Still work the same?
-jay
kurt murphy
on Jan 12, 2006 at 3:27:48 pm
Yes.
kurt murphy
