Texture
COW Forums : Zaxwerks
Tobsson
Texture
on Dec 24, 2005 at 11:13:57 am
I imported a model into invigorator but the textures are not showing up, they do in 3dsMax. So what should I do? I can
Jon Okerstrom
Re: Texture
on Dec 27, 2005 at 4:54:33 am
Hi Tobsson,
Textures do not automatically follow imported objects into Invigorator.
You may apply textures to some, but not all 3D objects you import into Invigorator. You do this by applying materials to the object, as you would any other Invigorator model. (materials are the way we describe a combination of surface attributes including color, specularity, image maps, bump maps, transparency maps, etc.). Unlike native Invigorator objects, there is a limit of one material per imported object... you would have to break down a complex imported model into separate parts to apply more than one material.
Does this help?
Jon
