bending text around object
COW Forums : Zaxwerks
Brandon
on Nov 30, 2005 at 12:11:57 am
I am trying to bend text around a round object, but it proves difficult positioning each letter around the object and make it look right. Then I want to rotate around the object. Is there an easy way to do this. Thanks
Brandon
Re: bending text around object
on Nov 30, 2005 at 12:47:43 am
Ok, I moved the text around the object and I am pleased, but when animate the rotation on my controller layer, it moves on the wrong axis. It spins instead of circling around the object. Is there a way to move the axis in the center so it circles around the object instead of spinning around on the front of the letters
Brandon
on Nov 30, 2005 at 1:54:21 am
Ok...I figured everything out.
