Invggorator closes AE HELP!!!
COW Forums : Zaxwerks
Scott Boyd
on Nov 28, 2005 at 10:39:53 am
Hi all,
A few weeks ago I place a post here about invgorator closing AE, Well I havent any luck fixing the problem yet so I will go into more detail about it,
All was working very well until a few weeks a go , I just started a new project an stated Invig to import a new Illst. file. I click the setup up button then After effects just closed instantly.. No matter what I do It just keeps happening.
I can get to the point where I have Invigorator running , I can move things around in the preview window but as soon as I click the red button AE closes ( If I click options in Invig AE also closes) Its driving me nuts!!
I down loaded the newest demo of Invig Pro and the same thing happens.
All other apps and plug ins seem to be ok
I did remove and reinstall both AE abd Invg
3.00 gigahertz Intel Pentium 4
16 kilobyte primary memory cache
1024 kilobyte secondary memory cache
c: (NTFS on drive 0) 23.32 GB 9.38 GB free
d: (NTFS on drive 0) 36.70 GB 15.58 GB free
f: (NTFS on drive 2) 80.06 GB 77.70 GB free
g: (NTFS on drive 1) 123.51 GB 61.67 GB free
NVIDIA GeForce FX 5200 [Display adapter]
Targa 15.7 [Monitor] (15.7"vis, September 2001)
drive] (60.02 GB) -- drive 0, s/n 3HR066TT, rev 3.05, SMART
Pinnacle Systems DV500 E4
Pinnacle Systems DV500 Overlay
Realtek AC'97 Audio
Adobe After Effects Version 5.5
Adobe Illustrator Version 10.0 Build 76
Adobe Premiere Version 6.
Matt Rhodes
Re: Invggorator closes AE HELP!!!
on Nov 28, 2005 at 4:40:01 pm
Hi Scott.
Would you mind sending me your troublesome .aep file?
I'd like to see if the problem occurs on this end.
Please zip the file and email it to: matt@zaxwerks.com
I only need the .aep file -- no media files.
Thanks.
Matt Rhodes
Zaxwerks, Inc.
Scott Boyd
on Nov 29, 2005 at 8:21:05 pm
Hi Matt,
There is not any particular file, it happens on all projcets enven new ones. I just cant get past the set up window with out the whole show closing down on meon me
Matt Rhodes
on Dec 1, 2005 at 12:59:56 am
Hi Scott.
Try the following:
- Find the folder called "Zaxwerks Swatches"
- Rename the folder to "Previous Swatches"
- Try your scenes again. Note that you won't see any swatches in the Swatch bins.
If this works for you, please compress your "Previous Swatches" folder and email
it to me: matt@zaxwerks.com
If this doesn't help the situation, delete the "Zaxwerks Swatches" folder
that may have been created when you tried again -- and then rename
"Previous Swatches" to "Zaxwerks Swatches."
Let me know how things go.
Matt Rhodes
Zaxwerks, Inc.
Scott Boyd
on Dec 2, 2005 at 12:31:16 pm
No luck, I tried that and it made no differance.
Have youn any other Ideas, Cus I luv my Invig and i miss being able to use it
