Creating a Ribbon with Invigorator
COW Forums : Zaxwerks
smeddolls
on Nov 23, 2005 at 10:08:59 pm
I have done Serge's tutorial and it's working well except for two things:
1) The transparency layer map doesn't seem to be working. I have a mask that reveals the white strip behind it, and it doesn't seem to be reading the hi-con info for transparency. (Even when I used the transparency map layer from his project) Is there something I'm missing?
and
2) I can only see the texture mapping when my comp is at half resolution, when I go to full resolution it goes back to a plain gray texture.
Thanks for the help...
kelly
