Invigorator Crashes
COW Forums : Zaxwerks
Bob Rahfeldt
Invigorator Crashes
on Nov 22, 2005 at 11:41:35 pm
I'm having problems with invig crashing when i try to open the options palette in 3d invigorator. It happens pretty much everytime i work with it. It works fine the first time I open the options window, but everytime after that After Effects crashes. Any help would be appreciated.
Bob
Matt Rhodes
Re: Invigorator Crashes
on Nov 23, 2005 at 1:20:40 am
Hi Bob.
Could you tell me:
- Are you running Windows or OS X?
- Which version of Invigorator are you using?
- Are you using Invigorator Classic or Invigorator Pro?
- Are you doing anything once inside the Set-Up window?
If you're getting repeatable crashes on a particular scene, would you
mind sending it to me: matt@zaxwerks.com
You can just send me the .aep file -- no media files necessary.
Let's start with that.
Thanks.
Matt Rhodes
Zaxwerks, Inc.
