Jitter
COW Forums : Zaxwerks
doug
Jitter
by
on Nov 18, 2005 at 2:17:59 am
Hello,
I have a word the has a psd file mapped to the side. the camera trucks across the top of the word, so the word moves from right to left. When i import it into my editor (media 100/844x) it looks real jittery.
Does anyone have a solution? settings Best, Full, with alpha
doug
hail the cow
Jon Okerstrom
Re: Jitter
on Nov 19, 2005 at 1:58:17 am
Hi Doug,
Are you saying your entire animation movie looks jittery, or the image mapped onto the Invigorator object?
I would check to be sure the field order and frame rate of the Invigorator movie matches the specs of your Media 100 system. If you're getting some buzzing on high-contrast horizontal lines, you could use a more aggressive antialiasing setting when you render your Invigorator movie.
Does this help?
Jon
