2 layers, only 1 shows
COW Forums : Zaxwerks
thew
by
on Nov 15, 2005 at 9:10:08 pm
I have a graphic that has been through the Illustrator process, etc..
However when I import the graphic, I lose on of my layers..
I select import layers, but the 2nd layer is lost in the graphic..
Any Ideas..
serge
Re: 2 layers, only 1 shows
on Nov 15, 2005 at 11:43:39 pm
If I got you right all you need to do is to select your object and move it apart from the rest of your objects using the apropriate tool.
Does this help?
Salut.
Serge
thew
by
on Nov 16, 2005 at 1:55:00 pm
Serge,
I can only select it in the set up window where you add textures and color..
When I attempt to move it, the whole its just spins the object now x and y..
In the scene preview it will only select the whole object is selcted.
How do you seperate and move them??
Better yet, know of any tutorials that get more in depth??
thew
by
on Nov 16, 2005 at 1:58:43 pm
Never mind, I gots it, had to select the directional tool up and down, then select the object..
Thanks though
