rotating letter problem
COW Forums : Zaxwerks
Brandon
on Nov 11, 2005 at 8:38:56 am
I am trying to rotate a letter but when I rotate it, I need it to be the same on both sides, how do I do this? It's flat on one side and has 2 stacks on the other side. Thanks
serge
Re: rotating letter problem
on Nov 11, 2005 at 6:16:34 pm
Hi Brandon,
I guess you applied an object style then a regullar Outside Edge. In this case you need to go to the Set-Up window, click on the Material Set-Up and in the Palette menu you click on Clear all splits.
Let us know if you still have problems.
Salut.
Serge
