object rotation help
COW Forums : Zaxwerks
djeddy
on Nov 10, 2005 at 10:21:10 pm
i'm pretty new to using invigorator. i imported an .ai of a mouse cursor. moved it to the center pivot and now i am trying to have it rotate on its own y-axis..but apparently after assigning it to a set..it doesnt stay on the axis, instead it orbits around the camera or moves in different areas (shrinking and increasing in size).
then i tried to orbit the camera..but the camera itself is a pain to keep still as well..
is there a way to make this object rotate on its own y-axis at all????
or is it something only the invigorator pro can do?
please help!!!
serge
Re: object rotation help
on Nov 11, 2005 at 4:50:15 am
Hi Djeddy,
Did you select your object in the Scene Preview window and recenter it's pivot point in the set menu?
Salut.
Serge
