ProAnimator render problems...jagged alpha edges + AE antialising problem
COW Forums : Zaxwerks
CabbeCabbe
on Nov 3, 2005 at 3:58:58 pm
two problems...
first.
when i render a animation from ProAnimator with alpha the egdes are very jagged....i tried all of the diferent render settings but none of them looks good. How do i get a render with nice alpha edges??
second
when i import a ProAnimator made .mov into After Effects the file again looks jagged...and not just the egdes. The whole file looks like it's not antialised. I tried exporting from ProAnimator without fields...upper fields...lower fields....but it all looks bad
if i open the .mov in quicktime everything is clear and antialised...so i must be importing the file wrong???
Jon Okerstrom
Re: ProAnimator render problems...jagged alpha edges + AE antialising problem
on Nov 7, 2005 at 5:11:17 am
Hi CabbeCabbe,
When you import the ProAnimator file, take a look at the interpret footage settings for After Effects. Be sure the field order and alpha channel settings are correct.
Does this help?
Jon
CabbeCabbe
on Nov 8, 2005 at 12:37:53 pm
that helped! thanx alot...
michael nilsson
on Jan 16, 2006 at 9:40:49 pm
I don't understand this. I have the exakt same problem and none of the checkboxes in "Interpret footage" solves the problem. I have a 720x576 PAL quicktime file from PA that looks very bad in AE. I want to preserve the alpha. What should my settings be like?
Regards, Mike
Mark Frost
on Jan 22, 2009 at 10:59:50 am
What should the settings be in interpret footage?
I am getting the jagged edges whatever I pick?
