3d objects and controllers
COW Forums : Zaxwerks
Billie O.
on Oct 27, 2005 at 9:49:13 pm
This is a two part question. First when I try and use 3d objects in Zaxwerks, they seem to disappear when I chech the use comp camera button. I am using a comp camera, zaxwerks layer and a controller.
The next question is regarding controllers. When I import a 3d object such as a lwo file, the imported object is not responding to the controller while objects generated in zaxwerks are fine. Any ideas?
I have just started with Zaxwerks and am sure this is all user error so any info will help.
Billie O.
Billie O.
Larry Butcher
Re: 3d objects and controllers
on May 9, 2006 at 7:21:30 pm
Did anyone respond to this? I'm having the exact same problem. And, oddly enough, I live in Seattle as you do.
Serge
on May 9, 2006 at 8:41:39 pm
Not to have your object disappear once you switch to the AE Camera you should do the following:
-In the Scene Preview window in camera mode, Click on Front View.
-Now, check the use AE Camera box.
As to question #2 I assume that you are referring to the Set controllers. Right?
In this case, make sure in the Set-Up window that your object is assigned to a set other then Set (0). I remember an older version of Invigorator that used to import 3D objects to Set (0) by default.
Does this help?
Salut.
Serge
"InvigoMany" Now available here:
http://www.nyc-visual.com
