need help, i need more than just 8 sets for 3d tracking
COW Forums : Zaxwerks
Brandon
on Oct 22, 2005 at 7:31:44 pm
I am using 8 3d tracking layers for 8 different letters in my project. I have these layers animated to animated the letters in the invigorator. But, I have another object i need to track with a layer. When I change set 1 to use for my 9th object, it takes out my motion for set 1. Is there a work around? Thanks
John Dickinson
Re: need help, i need more than just 8 sets for 3d tracking
on Oct 22, 2005 at 9:14:00 pm
Duplicate the effect and that gives you another 8 sets then just delete the objects you don't need.
JD
John Dickinson
Motionworks
http://www.motionworks.com.au
Brandon
on Oct 23, 2005 at 12:24:53 am
Just duplicate the invigorator? Will the objects still be able to interact? Thanks
Serge
on Oct 23, 2005 at 7:02:24 pm
No. The objects won't interact. The method is helpful if you are animating a set that always is in the BG or FG.
You could either duplicate the Invigorator effect, check "Composit on original" or duplicate the entire solid.
Salut.
Serge
