Largest Texture/Layer Map for Invigorator Pro
COW Forums : Zaxwerks
Stephen van Vuuren
on Oct 21, 2005 at 6:19:41 pm
Is there a way to use 30,000 x 2000 pixels maps in Invigorator Pro? I keep crashing it trying to use them.
Or what the largest map size is - can't see to find it anywhere...
stephen
http://www.stephenv2.com
336-856-8684
serge
Re: Largest Texture/Layer Map for Invigorator Pro
on Oct 22, 2005 at 1:33:08 am
Hi Stephen,
The size that crashes AE is the limit I would say.
When do you crash? By previewing, final render, animating or right away when applying your texture? Do you get any warning?
What version of Invigorator are you using?
Salut.
Serge
Stephen van Vuuren
on Oct 22, 2005 at 1:56:46 am
I got a reply from tech support 4000 x 4000 is it and you need to avoid use High Q Open GL renderer. It crashes as soon as you import the map.
