material setup problem
COW Forums : Zaxwerks
Laurie Pepper
on Oct 18, 2005 at 2:57:59 am
Used to be, when I hit "material setup" I got the palette and a map front, back, sides. Now I just get scene preview. No map. No way to put material "one" at one spot, Material "two" at another and so on. Any suggestions? I need my little layout sketch!
http://straightlife.org
Jon Okerstrom
Re: material setup problem
on Oct 26, 2005 at 3:30:00 am
Hi Laurie,
The material set-up window you're talking about works with native Invigorator objects. If you've selected an imported object, then clicked the material set-up window, I don't believe you'll see the cross section of the object, because you can't split materials for imported objects in the same way you can split material assignments for native Invig objects and text.
Does this help?
Jon
Laurie Pepper
on Oct 26, 2005 at 4:27:10 am
Yeah. I was actually trying to do it with an invig 3d primitive. Which had no sides. Thanks. L.
