editing illustrator layers problem
COW Forums : Zaxwerks
Phil Biggs
on Sep 7, 2005 at 10:11:58 pm
Hi there,
I'm having a nightmare trying to reload / replace objects in Invigorator once editing the layers in Illustrator. The original file was imported with 'via layers' enabled but, after going back to Illustrator to tweak a few things (keeping the original layer structure intact) nothing happens when I click on the reload button in the setup window. When I try to replace the objects with the oversaved Illustrator file, it says there are no usable vectors (the vectors are fine as they work in a new test invigorator comp). Anyone any ideas? I really don't want to build the model again from scratch every time I edit something in Illustrator.
Cheers,
Phil
