text mapping
COW Forums : Zaxwerks
doug
text mapping
by
on Aug 31, 2005 at 1:23:30 pm
I have a ribbon that has a movie mapped to it. What i would like to do now, is add a reflection of text that flows across the ribbon as the camera pans acros. I have tried many diffeent setting with no luck. The text is a grayscale targa file. Can anyone point me in the right direction?
Hail the Cow!
Doug
Zax Dow
Re: text mapping
on Aug 31, 2005 at 11:28:26 pm
Hi Doug,
This isn't a particularly 3-D way of doing it, but here's a technique which may work for you.
- Take the image that is to be the reflection and flip it vertically
- Then use the alpha of the ribbon as a track matte.
- If you need to distort the image so it follows the shape of the ribbon you can use AE's Mesh Warp feature set to a low number of Rows and Columns (such as 1 x 3)
- Then blend a little of the image back onto the ribbon adjusting opacity to taste.
Zax
doug
Re: text mapping
by
on Sep 1, 2005 at 3:52:33 am
Gracias,
I shall give it a try.
Hail the Cow!
Doug
