Problem with deleting and clearing in setup window
COW Forums : Zaxwerks
John Rich
on Aug 23, 2005 at 2:05:59 am
I just upgraded to Invig Pro 4.0.5. When I hit "clear scene" or delete" in the setup window the type or solid is deleted, but the window doesn't redraw, but just leaves all the fields blank. The only way out is Cntl Z which brings up the button to leave the setup window and I'm back to effect window. I never tried this with other earlier versions, but am I doing something wrong here? Is it possible to create a 3D object in the Set up window, or do you have to do all the deleting and recreating a new object in the effect window. Thanks.
John Rich
Matt Rhodes
Re: Problem with deleting and clearing in setup window
on Aug 29, 2005 at 3:36:34 pm
Hi John.
We're currently looking into a bug regarding clearing scenes in the Set-Up window.
This should be fixed in version v4.0.6.
Stay tuned.
Matt Rhodes
Zaxwerks, Inc.
