Invigorator 4.0 user prefs
COW Forums : Zaxwerks
Dave
by
on Jul 28, 2005 at 8:13:57 am
Hello,
I'd like to set the Y axis to "0" for the dupulicate offset.
For some reason, it changes back to default (-50) after typing in 0 in the box.
I clicked on save settings before hitting ok, but it still goes back to -50.
This is annoying especially when I'm trying to create something like a fence.
I'd appreciate it if someone could give me an answer to this.
Thank you
Matt Rhodes
Re: Invigorator 4.0 user prefs
on Jul 28, 2005 at 3:54:28 pm
Hi Dave.
Which version (v4.0.?) are you using?
Are you on the Mac or PC?
I'll take a look.
Matt Rhodes
Zaxwerks, Inc.
serge
on Jul 29, 2005 at 12:25:46 am
After typing in your new value, first hit Enter then save & hit Ok.
Salut.
Serge
Dave
by
on Jul 29, 2005 at 2:23:32 am
Thanks for the reply Matt, I am using 4.0 pro on a PC.
Thank you, Serge. I will try that first and let you know.
Dave
by
on Jul 30, 2005 at 1:49:03 am
I got it to work by hitting enter on the main keyboard(I was hitting enter
on the numeric key). However, I can't save the settings as default even after
hitting save.
When I open the invigorator work window & go back to user prefs,
it's back to the original default 50, -50, 0.
Thanks again.
serge
on Jul 30, 2005 at 3:27:17 am
Hi Dave,
I would higly recomend you to download the latest version (4.0.5) of Invigorator Pro. This should take care of your problem and it's free. I remember having your issue in an older version but I am fine with 4.0.5.
Salut.
Serge
Dave
by
on Jul 30, 2005 at 5:18:52 am
Thank you very much, Serge. I will do as you suggest.
