No background photo
COW Forums : Zaxwerks
Bernard Ageeb
No background photo
on Jun 29, 2005 at 5:22:19 pm
i am putting together a clip with text and a photo in the back ground but when i do a render frame or render no back ground just tex? I am using Pro Animator. Thanks in advance.
Bernard
John Dickinson
Re: No background photo
on Jun 29, 2005 at 9:10:05 pm
It's a good idea to check the previous posts... you can find an answer to the same question much of the time. This is a quote from Matt Rhodes taken from down the page a little
" In version 3 of ProAnimator, the background is for alignment/placement only. It does not get rendered into the final output.
In version 4 (coming soon!), you are given the option to composite the background image into the final rendering. "
JD
