importing an illustrator curve with curves inside, NO HOLES!!!!
COW Forums : Zaxwerks
gybp
by
on Jun 24, 2005 at 12:43:30 pm
hi, im trying to create a 3d model from curves drawn in illustrator, these curves have curves inside to make holes, but these curves create new objects instead of making the holes, any workaround for this????
Jon Okerstrom
Re: importing an illustrator curve with curves inside, NO HOLES!!!!
on Jun 24, 2005 at 1:55:04 pm
Hi gybp,
Select both objects in Illustrator and use the make compound path command.
Jon
