primitives?
COW Forums : Zaxwerks
mike harper
primitives?
on Jun 21, 2005 at 7:32:29 pm
can you create simple shapes in pro animator? IE primitaives ? or is it text only?
thanks
Mike Harper
http://www.editscore.net/
Matt Rhodes
Re: primitives?
on Jun 21, 2005 at 8:01:42 pm
Hi Mike.
The current version of ProAnimator (version 3) allows you to import a variety of 3D file formats,
including OBJ, DXF, and 3DS.
Version 4 of ProAnimator (coming very soon) will let you create a variety of primitives, including
spheres, cylinders, cones, cubes, and pyramids.
Matt Rhodes
Zaxwerks, Inc.
Matt Rhodes
Re: primitives?
on Jun 21, 2005 at 8:01:40 pm
Hi Mike.
Matt Rhodes
Zaxwerks, Inc.
Marcelo Lewin
Re: primitives?
on Jun 22, 2005 at 4:26:35 pm
So then what will be the difference between Pro Anim and Invigorator? Will they be merging in the future (I don't own Pro Anim, so I'm be wrong at stating that they sound similar).
Marcelo Lewin
marcelo@thedailyfarce.com
http://www.thedailyfarce.com/
Zax Dow
Difference between ProAnimator and Invigorator
on Jul 2, 2005 at 12:11:56 am
Hi Marcelo,
The creation of objects, and the set up of the scene is exactly the same in both programs. The difference is the animation.
In the Invigorator you have to use AE's keyframes to animate the objects and camera. Oftentimes this can be frustrating and very time consuming, especially if you are doing anything fancy.
In the ProAnimator you create animations without using keyframes. There are controllers for animating the shape of the paths, where objects will start and end, and the timing of the objects as they move along their paths. By using controllers rather than keyframes it is much easer to create the animation and you can do it in far less time. Once an animation is created you can save it and apply it to any other set of letters or objects. This means you can create additional versions without having to recreate the animation.
The ProAnimator is truly a remarkable tool.
-Zax
