problem with rotation around an axis
COW Forums : Zaxwerks
banshee
on Jun 17, 2005 at 10:38:09 am
hi all,
I now succeeded in rotating seperate characters around the y-axis. Because I didnt like the standard bevel depth I decreased it. But now the y-axis isnt exactly in the middle of the characters but behind them so that they dont seem to turn but even change their position while rotating. I hope you can imagine this :]
Do you know how I can apply the y-Axis to that?
Matt Rhodes
Re: problem with rotation around an axis
on Jun 17, 2005 at 4:39:17 pm
Hi Banshee.
I assume you're using ProAnimator v3.0.
The object pivot isn't properly adjusted when changing the depth of the object.
In version 4 (coming soon), the objects are created so that the pivots are properly centered.
Matt Rhodes
Zaxwerks, Inc.
banshee
on Jun 18, 2005 at 9:22:43 am
No, I was using the 3D Invigorator v4.0.3 but I guess its the same problem.
Matt Rhodes
on Jun 18, 2005 at 8:33:34 pm
Yes. It's the same problem.
However, version 4.0.5 (released very soon) will fix this problem
by creating the object in a slightly different way.
Matt Rhodes
Zaxwerks, Inc.
