obj model strangeness
COW Forums : Zaxwerks
Tony Romain
on Jun 10, 2005 at 6:08:36 pm
anyone have any idea why an imported model would look like this:
http://home.comcast.net/~trancemedia/3dmodel.jpg
any way to fix it in invigorator? i can open the model in maya okay... just would prefer to use it in invigorator (making wireframes is waaaay easier in invigorator...)
Matt Rhodes
Re: obj model strangeness
on Jun 10, 2005 at 7:05:57 pm
Hi Tony.
If you could send me the model, I'll take a look.
Send to: matt@motivatedpixels.com
Thanks.
Matt Rhodes
Zaxwerks, Inc.
Glenn Moore
on Jun 11, 2005 at 4:37:51 am
Just a guess, it looks like it's still in high draft quality. Did you make any setting adjustments? Did you use Spikebuster?
Matt Rhodes
on Jun 13, 2005 at 3:11:19 pm
Hello everyone.
The problem Tony was experiencing was a bug in the Invigorator's OBJ parser.
The file is easy to fix with a text editor, and the next version of the Invigorator
will have a fix in the code.
The problem:
- The last portion of a line has: #####
(for example: 12345)
- We expected a space between the last number and the backslash
- So we did a little search and replace to create: #####
Then the file loaded.
Matt Rhodes
Zaxwerks, Inc.
