Viewing Shadows Scene Preview Window
COW Forums : Zaxwerks
Don Gray
on Jun 6, 2005 at 11:51:03 am
Is this "test" option a Mac only thing?
I see no way to view shadows in the Scene Preview window here using Windows.
Also, I think it would be good to be able to update the edits made in the Scene Preview Window
to the Invigorator Set Up Window, since all the Scene Preview edits are now lost when you hit the update button.
While I'm at it, I think being able to resize the Scene Preview window would be kind of nice too,
otherwise you have to wait for two updates to see a larger view, one in the Scene Preview window and the other in the comp window.
Otherwise, you could disable the comp window (Caps Lock) while viewing the larger scene view, needing only one update.
Don
Marcelo Lewin
Re: Viewing Shadows Scene Preview Window
on Jun 6, 2005 at 4:07:57 pm
If I'm not mistaking, I think if you hold the "CTRL" key you will see the "test" button appear. Click that and you will see the entire scene as it will appear rendered.
Marcelo Lewin
marcelo@thedailyfarce.com
http://www.thedailyfarce.com/
Don Gray
on Jun 6, 2005 at 4:29:26 pm
Thanks, Marcelo, but I don't see a test button when holding down the CTRL key.
Don
Marcelo Lewin
on Jun 6, 2005 at 5:31:11 pm
Hmmm.. That is strange. What version are you using? I think that works on both versions though. I'm on a PC. You might want to give them a call. They are awesome when it comes to customer support! They have an 800 number on their site.
Marcelo Lewin
Don Gray
on Jun 6, 2005 at 8:59:45 pm
I'm on a PC as well.
Where in the interface does the TEST button show up?
BTW, do any shadows show up at all in the SET UP dialog?
I am printing the PDF manual now.
Thanks again, Marcelo.
Marcelo Lewin
on Jun 6, 2005 at 9:10:18 pm
I have not played with Shadows much, but from what I understand, they should show up in the set up window. Just make sure you are in the scene preview (radio button at the top) and hold down the CTRL key. When you do, the "OK" button that you usually click to get out of the Setup window, should turn into a "Test" button.
I hope this helps. I don't have the Invigorator in front of me now, but I will check it out tonight and post here my findings re: Shadows.
Cheers!
Marcelo Lewin
Don Gray
on Jun 7, 2005 at 11:58:05 am
Uh, yeah, ok, I have it now.
I was looking for the operation to work in the Scene PREVIEW window.
Sorry, a novice's mistake.
Thanks Marcelo.
Marcelo Lewin
on Jun 7, 2005 at 1:57:45 pm
Hey! I'm a newbie myself...so no worries. Anyhow, I just tried adding a shadow to my 3D text and when I hit "test" in the scene preview, the shadow comes up. Just make sure you have selected Shadow Casting in the light setup.
CHeers!
Marcelo Lewin
Don Gray
on Jun 7, 2005 at 4:10:02 pm
Yep, got it now.
If I'm going to have objects, I most always am going to want shadows.
