Create 3D Primitive: Sphere Only?
COW Forums : Zaxwerks
Don Gray
on Jun 6, 2005 at 11:09:48 am
Like I mentioned previously, I am new to Zaxwerks and Invigorator Pro for AE.
I'm still waiting for the manual to come in the mail.
I have looked around in the various help dialogs but haven't seen anything related so I'll ask here,
when creating a 3D object, the sphere is the only option. I assume(?) there are more somewhere?
Otherwise the dialog would read "create 3D sphere" I would guess.
Where are these hidden primitives located?
While I'm at it is the Set Track 3D Layer option so you can use a 3D layer without AE telling you
not to set the regular Invigorator layer to 3D while using an AE camera?
Or as in my lighting/shadow post, is this layer where I put my 3D comp lights?
Off to try some of these things out.
Don
Marcelo Lewin
Re: Create 3D Primitive: Sphere Only?
on Jun 6, 2005 at 4:10:28 pm
I can answer two of your questions:
1) The book is in the zip file. It's a PDF. It's about 70 pages. I printed it. It's a really good book.
2) Re: Spheres only. Click on the Object tag. You will see there a pull down for the different types of primitives.
Hope this helps!
Marcelo Lewin
marcelo@thedailyfarce.com
http://www.thedailyfarce.com/
Don Gray
on Jun 6, 2005 at 4:56:09 pm
Oh, cool, thanks Marcelo!
I did find the object tab to change the object type and I'll take a look at the PDF.
Don
