how do i make the film strip twist or rotate?
COW Forums : Zaxwerks
Brandon
on Jun 6, 2005 at 2:43:46 am
I was wondering how would I make the film strip, the one in the tutorial, twist or turn? I want it to start out going kinda straight then curve towards the camera. Also, I want to have a depth of field look too. Where the first part is farther back and a little smaller and the end is bigger as it comes towards the camera. Thanks.
Brandon
Jon Okerstrom
Re: how do i make the film strip twist or rotate?
on Jun 6, 2005 at 3:05:31 am
Hi Brandon,
Second question first: try adjusting the camera lens to wider angle. This amplifies the difference between how objects near and far appear and should give you what you're after.
First question: without looking at the tutorial, I'd use layer cycling to animate the shape of a path which becomes the edge of the film strip in Invigorator. Perhaps this will give you some ideas.
Jon
Brandon
on Jun 6, 2005 at 4:12:11 am
Thanks, I'll give it a try.
Brandon
on Jun 6, 2005 at 4:36:37 am
Ok, I looked for layer cycling, but I couldnt find it. Can you give me a little direction? Thanks.
Marcelo Lewin
on Jun 6, 2005 at 4:22:29 pm
Here is a tutorial on Layer Cycling:
http://www.creativecow.net/show.php?page=/articles/okerstrom_jon/layercycle...
Hope this helps.
Marcelo Lewin
marcelo@thedailyfarce.com
http://www.thedailyfarce.com/
Jon Okerstrom
on Jun 7, 2005 at 2:40:40 am
Thanks, Marcelo,
Instead of doing a write-on effect as the tutorial demonstrates, simply vary the shape of the stroke slightly in each layer to make the film strip edge appear to animate.
Jon
Brandon
on Jun 7, 2005 at 3:15:56 am
Thank you very much.
