this is kind of weird-cant open file in ProAnimator but can in Invigorator
COW Forums : Zaxwerks
brandon
on May 16, 2005 at 8:55:23 pm
I traced a logo using paths then filled the paths in. Then I was using Invigorator in AE, then I decided to use ProAnimator for the same file, but it gives me an error saying there are no useable vector paths. Why is it that I can open it in Invigorator in AE, but I cant in ProAnimator? Isn't that weird?
Brandon
Matt Rhodes
Re: this is kind of weird-cant open file in ProAnimator but can in Invigorator
on May 17, 2005 at 12:57:27 am
Hi Brandon.
If you're using Invigorator 4.x and ProAnimator 3.x, then there's a chance we
fixed a bug that made it into Invig 4.x -- and will be available in ProAnimator 4.x
when it is released.
Matt Rhodes
Zaxwerks, Inc.
Zax Dow
on May 17, 2005 at 5:52:45 pm
....... that bug was probably compatibility for Illustrator CS files.
Until version 4 of ProAnimator is released, just save your file as an earlier version of Illustrator and it should open up fine.
-Zax
