Mapping ae layer
COW Forums : Zaxwerks
Nick Reiber
Mapping ae layer
on May 16, 2005 at 4:32:44 pm
The Zaxwerks website says you can map a layer from an after effects comp onto a 3d object. But how is this done? I have made a 3d TV screen and wish to map content on the screen.
kurt murphy
Re: Mapping ae layer
on May 16, 2005 at 7:46:29 pm
It's a couple-step process for a map that has moving images:
You'll import a movie or create a comp with the images that you want to map onto the screen. Bring this comp or movie into the comp that has the Invig layer. In the Invig Effects Control window, select the layer that contains the comp or movie that you want to map under Layer Maps (on the bottom of the effect window). Next go into the Edit mode (click the red ball) and select the color ball that you want to use as the map. The top square has a place to select the Layer Map. You won't be able to see if it works until you exit the edit screen and have the layer at full (not draft) mode.
Hope this helps,
kurt
