glow question
COW Forums : Zaxwerks
Dave Hirschberg
glow question
on May 12, 2005 at 3:28:36 pm
I created a neon light and want it to glow but I don't want the object it is over to glow. Is there a way to add a glow to one object and not another in the same comp window?
Matt Rhodes
Re: glow question
on May 12, 2005 at 3:45:22 pm
Hi Dave.
Easy Glow (part of The Werks Vol. 1) provides a Glow Style called "Out-Glow", which will
put a glow on the outside of the object, leaving the inside intact.
This is probably what you would use for a good neon glow.
You can even change the Glow Color From parameter to "This Layer", which will make your
layer's color the glow color.
Give this a try and let us know if you have any other questions.
Matt Rhodes
Zaxwerks, Inc.
Dave Hirschberg
Re: glow question
on May 12, 2005 at 3:50:27 pm
Will this work in AE 5.5?
Matt Rhodes
Re: glow question
on May 12, 2005 at 7:47:04 pm
Hi Dave.
Absolutely.
Matt Rhodes
Zaxwerks, Inc.
