Newbie to INVIG.
COW Forums : Zaxwerks
crjoe
Newbie to INVIG.
on Apr 29, 2005 at 8:56:02 pm
I have tried, and unfortunately I don't know much about Invigorator or Illustrator, but how do I get a Illustrator text file with vectors so that I can import them into Invigorator. I have tried saving the files as AI8 files but Invigorator still says they are not valid files.
Any help would be appreciated.
Crjoe
Glenn Moore
Re: Newbie to INVIG.
on Apr 29, 2005 at 10:00:54 pm
You first must Convert the AI file to Outlines. Select the text (or shape) then go to 'Type' in the toolbar and then Convert to Outlines. Save the file as a an AI file. In Invig, select the option you want (Open an Illustrator File). A pop up window will open. You point to the file and it will be transferred and converted from Outlines to a 3D object. You don't manually bring the file in. Let the program find it and import it. From there, it's all you. Tweak away. I hope that helps and is clear enough.
crjoe
on Apr 30, 2005 at 3:44:43 am
Thanks for the help. I couldn't figure that out.
This is great.
crJoe
Glenn Moore
on Apr 30, 2005 at 4:16:35 am
Glad you got it to work. It is a very cool app. You may want to scan the book and browse some of the tutorials. I dont use it for everything but I can always find some use for it in my projects.
