Layer Map is applying itself to surface 1 on every object
COW Forums : Zaxwerks
Sean
by
on Apr 19, 2005 at 4:55:36 pm
Of course I know that I'm doing something wrong...
I made a rectangular box that I'm using for a video screen, but I decided I wanted 3 of them, so I use the duplicate object and made 3 of them. They all can be assigned to diffrent sets and act as 3 independant objects, BUT when I go and assign a layer map on the front surface of the first box, it applies itself to the front surface of ALL the objects. So, Was it because I use the duplicate feature? Should I have made 3 seperate boxes from scratch? Thanks for the help!
Sean
Matt Rhodes
Re: Layer Map is applying itself to surface 1 on every object
on Apr 20, 2005 at 5:57:22 pm
Hi Sean.
When you duplicate an object, it links the original materials to the duplicated objects,
as you've seen.
To remove this link, do the following:
1. Open the 3D Invigorator Set-Up Window
2. Select a duplicated object
3. Open the Object Styles tab in the upper-right corner of the Set-Up window
4. Find the Swatch menu next to the Object Styles tab
5. Select "Unlink Object Style"
6. Repeat steps 2-5 for additional objects
Your selected object(s) will now be independent of the original object, so you can
specify a different object style or material for each one.
Try the steps above and let us know if you need more assistance.
Matt Rhodes
Zaxwerks, Inc.
