IS ADOBE ILLUSTRATOR The only game in town.
COW Forums : Zaxwerks
Paul Whishaw
on Apr 6, 2005 at 6:58:23 am
Is Adobe Illustrator the only way to get text objects into Zax? I have Freehand but I'm still stuck running AI in Classic mode with a spattering of pathetic fonts. Have they at least upgraded to alow versions higher than AI 9? Just curious. Thanks in advance.
Max
Re: IS ADOBE ILLUSTRATOR The only game in town.
by
on Apr 6, 2005 at 11:16:21 am
Hi Paul,
It is not compulsory to use Adobe Illustrator.
I use CorelDraw12, convert my texts to curves, then export to AI (version 7) and so far have not hit a single problem. Once in Invig or in ProAnim I would set the Spikebuster to 100 and choose the appropriate edges. All can be found under the Objects tab.
As for the version higher than AI (V9), I also use Adobe Illustrator CS and found no related issues with the either of these applications.
Hope this helps
Regards
MaxC
Matt Rhodes
on Apr 6, 2005 at 3:27:05 pm
Hi Paul.
Version 4.x of Zaxwerks Invigorator 3D and any version of ProAnimator has a Text editor built in,
so in many cases, you won't need to import any outlines. You can do all of your editing within Invigorator.
Take a look at the demo version to see if it fits your needs.
Let me know if I can offer further assistance.
Matt Rhodes
Zaxwerks, Inc.
