Can TextBlocks be indivually animated in 3d Invig Pro 4.0
COW Forums : Zaxwerks
dante pignetti
on Apr 5, 2005 at 6:46:01 pm
Hi all,
if u key in your type in 3D Invig Pro, is it then possible to animate each letter individually?
when i click on the letters individually and then set their "layer set", it will change them all.
I guuess my quesiton is, can "TextBlocks" be individuall animated like they are in ProAnimator?
thx
Matt Rhodes
Re: Can TextBlocks be indivually animated in 3d Invig Pro 4.0
on Apr 5, 2005 at 8:31:56 pm
Hi Dante.
Animation in 3D Invig Pro is done by Sets, as you know.
To place each letter in a separate group, you'll need to select each letter individually.
To select an individual letter in a Text Block, do the following:
- Make sure none of the letters are selected
- Holding the Shift key, click on a letter
- Still holding the Shift key, click on additional letters as necessary
- Select the Set number for the selected letters.
Let me know if you have other questions.
Matt Rhodes
Zaxwerks, Inc.
